Using a steady state for initial conditions in transient... |
#1 | |
Mark Herskind
Rep Power: 15 ![]() |
I'm trying to run a simulation, which is pretty unstable...
I would like to initialize my transient simulation from a steady state simulation... My setup is in Workbench 21R1 using RSM, and I do 5000 iterations in my SS, which converges fine.. When I start my transient simulation I get this warning: Quote:
I can't seem to find the option to use my defined timestep (1e-6).. I usually work i OF/CFX, so Fluent is a bit unknown to me, so sorry if this is very simple issue... Thanks Mark |
Chris
Rep Power: 9 ![]() |
Hi Mark,
since I encounter the same warning with a comparable setup, I wonder if you found a solution? I contacted Ansys support, but they couldn't help me quickly and will call me back. Maybe you have a faster solution? ![]() Best regards Chris |
Alexander
Rep Power: 34 ![]() ![]() |
run fluent standalone (without workbench) there should be no problems
best regards ****************************** press LIKE if this message was helpful |
Chris
I can't because fluent standalone doesn't support it's own in-house cluster management system / scheduler (RSM+ARC). You have to use workbench for that. Ansys support told me this will be looked into in future releases. Both, support of RSM in fluent standalone and the time-step size problematic.
For now there are two workarounds: 1. set the physical time step within the previous stationary simulation even though you don't need it (rpsetvar 'physical-time-step 0.001) this will then be saved in the settings file and the warning is gone. 2. use the "automatic initialization of the solution and case modification" option within fluent (the transient simulation setup) to set the time-step automatically between initialization and the first time-step. You will still get the warning and the time-step will be set back to the default value but it's then being overwritten. I hope this explanation is clear and helpfull. |
Steady state solution ----> transient | nskelly | OpenFOAM Running, Solving & CFD | 4 | March 12, 2018 11:49 |
Convergence in steady state simulations vs transient ones | cardioCFD | CFX | 5 | January 21, 2018 10:59 |
vortex shedding, transient or steady state analysis type? | alfonsojurado | CFX | 0 | October 25, 2012 05:33 |
Steady state vs. mean transient analysis of flow behind a circular cylinder | Heini | Main CFD Forum | 1 | June 9, 2011 06:47 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 14:37 |
