dynamic mesh
Old   May 12, 2021, 10:25
Default dynamic mesh
ali
ali_bizhanpour is on a distinguished road
Hi all
I trying to use Six DOF UDF with one DOF rotation for simulating a moving guide vine in a water pipe with a diameter of 0.1 meter and I set mass flow rate equal to 11 kg/s for inlet boundary condition. I face this error every time.
Error: Update-Dynamic-Mesh failed. Negative cell volume detected.
Error Object: #f
I tried different time steps, even less than 1e-6 but the problem was not solved.
this is my UDF :
#include "udf.h"
DEFINE_SDOF_PROPERTIES(blade, sdof_prop, dt, time, dtime)
Six_DOF_Object *sdof_obj = NULL;
sdof_prop[SDOF_MASS] = 0.053;
sdof_prop[SDOF_IXX] =2.2e-6;
sdof_prop[SDOF_IYY] = 4e-6;
sdof_prop[SDOF_IZZ] =5.5e-6;
sdof_prop[SDOF_LOAD_M_X] = 0.0;
sdof_prop[SDOF_LOAD_M_Y] = 0.0;
sdof_prop[SDOF_LOAD_M_Z] = 0.0;
sdof_prop[SDOF_SYMMETRY_X] = 0; /* normal vector of symmetry plane for half model */
sdof_prop[SDOF_SYMMETRY_Y] = 1 ;/* normal vector of symmetry plane for half model */
sdof_prop[SDOF_SYMMETRY_Y] = 0 ; /* normal vector of symmetry plane for half model */
sdof_obj = Get_SDOF_Object(DT_PU_NAME(dt));
if (NULLP(sdof_obj))
/* Allocate_SDOF_Object must be called with the same name as the udf */
sdof_obj = Allocate_SDOF_Object(DT_PU_NAME(dt));
SDOFO_1DOF_T_P(sdof_obj) = FALSE; /* one DOF translation */
SDOFO_1DOF_R_P(sdof_obj) = TRUE; /* one DOF rotation */
SDOFO_DIR(sdof_obj)[0] = 0.0;
SDOFO_DIR(sdof_obj)[1] = 1.0;
SDOFO_DIR(sdof_obj)[2] = 0.0;
SDOFO_CENTER_ROT(sdof_obj)[0] = 0.09354; /* only needed for one DOF rotation */
SDOFO_CENTER_ROT(sdof_obj)[1] = 0.0; /* only needed for one DOF rotation */
SDOFO_CENTER_ROT(sdof_obj)[2] = -0.01; /* only needed for one DOF rotation */
SDOFO_CONS_P(sdof_obj) = TRUE; /* constrained */
if (SDOFO_CONS_P(sdof_obj))
SDOFO_LOC(sdof_obj) = 0.0;
SDOFO_MIN(sdof_obj) = -0.1745;
SDOFO_MAX(sdof_obj) = 0.1745;
SDOFO_F(sdof_obj) = 0.0; /* spring preload */
SDOFO_K(sdof_obj) = 2.76; /* spring constant */
SDOFO_INIT(sdof_obj) = SDOFO_LOC(sdof_obj);
SDOFO_LOC_N(sdof_obj) = SDOFO_LOC(sdof_obj);
these are my dynamic mesh setting:
ali_bizhanpour is offline   Reply With Quote
dynamic mesh
Mesh Disappering with Dynamic Mesh FaroukH FLUENT 0 February 23, 2021 19:26
[snappyHexMesh] non uniform mesh near the stl object vava10 OpenFOAM Meshing & Mesh Conversion 0 January 31, 2021 15:41
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 09:27
[ICEM] Dynamic mesh setup with ICEM David121284 ANSYS Meshing & Geometry 0 April 11, 2014 05:19
Dynamic Mesh "Shadow Wall" thezack FLUENT 0 June 4, 2013 23:09
