Wrong solution with a converged solution
Old   May 12, 2021, 06:11
Default Wrong solution with a converged solution
Alvaro
alvarrapi9 is on a distinguished road
Hi to everyone,
I have a 2D axysmetrical thruster simulation, internal, steady and laminar with compressible flow and energy equation. The point is that after establishing a pressure-inlet condition in which I fixed the gauge pressure and the temperature I get a converged solution (low and stable residuals and stable variables (I plot different averages and all of them are stabilised) but the problem is that even the solution seems to be really converged the inlet values are not the one I input.
For example, depending on the geometry I get values between 630K-655K on temperature but not the 673,15K that I fixed (same with the pressure). I do not think there are any problems with the mesh as long as I have previously done a grid independent study and the results were fine. I would really appreciate some guides about what can be going on as I have tried a lot of things but the solution still not reach the values I have established at the inlet even it is converged.
Thank you!
alvarrapi9 is offline   Reply With Quote
Old   May 13, 2021, 20:25
Lorenzo Galieti
LoGaL is on a distinguished road
Which values are you extracting from the simulation? Static Temperature and Pressure? Just to tell you that your boundary conditions impose the total ones
LoGaL is offline   Reply With Quote
Old   May 14, 2021, 05:00
Alvaro
Thank you for the answer! I am extracting the static values. However, I consider that the pressure and temperature are the total values so I input these values in the boundary conditions calculating them with the same procedure that Fluent does (Cp constant and compressible flow). The problem is that I am not reaching the static values and If I change the geometry even the boundary conditions are the same the reached values changes again...
convergence, fluent, wrong solution
Solution tends to wrong (or not wanted) value Captain Convergence Fluent UDF and Scheme Programming 14 April 14, 2020 07:15
UDF for Automatic Solution Initialization for previous case data file gartz89 Fluent UDF and Scheme Programming 6 March 30, 2020 08:38
inviscid transonic RAE2822 - unable to get a converged solution ksklemmer STAR-CCM+ 2 July 28, 2015 12:20
Wrong solution after parallelisation Martin_K_lalelu OpenFOAM Programming & Development 0 December 12, 2014 07:21
Is the solution converged or not?? yahmed FLUENT 1 March 19, 2014 17:27
