May 11, 2021, 07:45 |
Angle evaluation
Vasif Can YILDIRAN
Rep Power: 8 |
Dear all,
I analyzed a pipe case for fluent. And, I examine uniformity and flow behavior for axial flow on cross section of pipe. The cross section is control surface for me. For this control, I'm trying to evaluate phi angle on control surface about velocity vectors. We can imagine that x is axial direction defined by axis of the outlet pipe, y represents tangential and z represents radial direction of cylindrical coordinate system. My question is how I can define the angle form y (tangential) direction to the phi angle variation in range (-phi, phi) on post process of Ansys? Does velocity angle contour plot cover it? Or, Should I write expression to create phi angles range for velocity vectors on control surface? Thank you. |
angle evaluation, fluent, post process, uniformity index, velocity angle |
Dynamic contact angle calculation in multiphaseInterFoam | rajeshchem | OpenFOAM | 3 | December 23, 2022 14:00 |
Dynamic contact angle issue: fluent UDF couldn't set the correct contact angle | FelixJJ | FLUENT | 2 | October 20, 2021 02:39 |
Winglet cant angle effects | frossi | FLUENT | 0 | March 31, 2017 19:35 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
Normal vector, slope and aspect angle | g_niro | Main CFD Forum | 0 | February 2, 2011 17:24 |
