Fluent's Macroscopic Particle Model (MPM) vs Star CCM's Discrete Element modelling?
Old   May 7, 2021, 08:22
Post Fluent's Macroscopic Particle Model (MPM) vs Star CCM's Discrete Element modelling?
Ethan McGrath
mcgart25 is on a distinguished road
Does anyone know what advantages Fluent's Macroscopic Particle Model (MPM) has over Star CCM's Discrete Element Method (DEM) when it comes to modelling multi-phase flow containing super-grid particles (i.e. those larger than the minimum mesh size)? I understand that both exhibit four-way coupling, but DEM also allows for the deformation of particles to be accounted for where MPM does not, so I can't seem to think of many instances where MPM is preferable? Is the only advantage that MPM is less computationally intense (I'm assuming this is probably the case)? Or are there other ways in which MPM is advantageous?
mcgart25 is offline   Reply With Quote
dem-cfd, macroscopic particle, particle multiphase, star ccm+, super grid particles
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM Ancioi OpenFOAM Meshing & Mesh Conversion 17 January 9, 2019 00:50
Identifying Markers in a CGNS Mesh tjim SU2 3 October 12, 2018 02:21
Discrete Element Method Collision Model sfn Fluent Multiphase 5 May 27, 2018 10:25
How to simulate solid particle discharge from Silo using Discrete Element Method Billy_ FLUENT 0 January 25, 2018 06:18
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 06:29
