May 1, 2021, 17:31 |
Oscillation in lift coefficient plot
husam
Dear members,
I am running a simulation of flow around an airfoil. My case is transient. I am trying to calculate the lift coefficient, however, the lift coefficient plot is oscillating periodically and I am not getting a constant value for lift coefficient. - What is the correct way to calculate the life coefficient in transient cases? - Should the lift coefficient plot become constant in transient cases or it is normal to have oscillation? - is it correct to calculate the lift coefficient by running steady state simulation even if the case is transient? - or should I take the mean value of two peaks on the oscillating lift coefficient plot and consider it as a lift coefficient? Thank you in advanced |
Getting lift curve plot | tj___ | FLUENT | 0 | December 26, 2016 23:41 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
airfoil lift and drag coefficient | amir_14 | FLUENT | 5 | January 1, 2013 08:30 |
Lift force coefficient for 2-phase flow | Summer | FLUENT | 0 | April 29, 2008 17:58 |
Help needed - lift coefficient on front/rear axle | Jan Jagrik | FLUENT | 0 | September 21, 2000 10:21 |
