April 5, 2021, 09:02 |
Simulate composite PCM
maryam fallah
Hi everyone
I want to simulate PCM with metal foam, but to solve in the case of non-equilibrium scheme, I have to define function for heat transfer coefficient. I use the custom function of fluent But I can't use it in the Porous Zone part. In this case, can not the function be defined directly in Ansys fluent directly? or I must compile the code in the fluent? If anyone can help me I would be very grateful. |
composite pcm, metal foam, non-equilibrium, pcm, porous zone |
solidification and melting with VOF: how to sink solid PCM as it melts? | sakil2k3 | FLUENT | 32 | November 15, 2019 07:27 |
PCM melting inside the Al cavity | shoxan | FLUENT | 1 | August 9, 2018 03:12 |
melting PCM | maherm | FLUENT | 0 | June 19, 2012 10:44 |
Simulate the wind profile on a wind turbine---> HOW ???? | mohammad | Main CFD Forum | 0 | April 13, 2012 09:07 |
To perform charpy impact test of GLARE composite and to simulate this on ANSYS | umer virk | ANSYS | 0 | November 15, 2011 04:17 |
