Lift and Drag at Transonic Speeds are Orders of Magnitude from realistic values |
Rep Power: 0 ![]() |
I am relatively new to CFD, though I have done some before. This is my first time using Fluent, which I'm using to test lift and drag at a variety of Mach numbers and the results I'm getting are very odd (e.g. Drag force of 1e8). I will start at the beginning to explain what I'm doing. Following a Youtube tutorial, I started by building an aerofoil in Solidworks and importing it into the DesignModeler. The airfoil was rotated to a certain angle to represent the angle of attack. I created a reference volume around the aerofoil (extruded to the same depth as the airfoil itself) and used a Boolean operator to subtract the aerofoil from the reference volume. i.e. [IMG] https://imgur.com/sAcEFII [/IMG] I then created a mesh for this geometry. The mesh itself just a basic automated one, since at this point, I'm just looking for a rough answer. Following the tutorial, I setup the simulation in Fluent. The viscous model used is Spalart-Allmaras and the fluid is air, with the air's density determined using the ideal gas equations. The speed of the airflow at the velocity inlet was set as a input parameter so I could see how the lift and drag vary with the Mach number of the airflow. The output parameters were the lift and drag force evaluated across the aerofoil walls. I then set this simulation to run for a range of Mach numbers from 0.5 to 1.5. The simulation runs fine at Mach=0.5 and Mach=0.6, returning drag values of 98N and 238N respectively after a run time of 5-10 minutes. Unfortunately at Mach=0.7, the simulation takes well over an hour to run and returns a drag of 3000N, and for Mach=0.8, it says the drag is around 1x10^8N, which is quite obviously wrong. Any advise? I have added a link at the bottom to a zip file containing the simulation if you wish to look over it yourself. Thanks. Link: Fluent Simulation.zip - 34.8 MB |
Calculation of lift and drag coefficients on airfoil | CoolHersheys | OpenFOAM Post-Processing | 5 | September 27, 2021 06:04 |
Conflicting Lift and Drag coefficient values in OpenFoam | Akin-iii | OpenFOAM Running, Solving & CFD | 1 | October 15, 2020 17:46 |
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 05:18 |
Lift Drag and Reference Values in 2D | kike | FLUENT | 0 | July 9, 2015 17:52 |
Lift and Drag Monitor Point Values Converging to Zero | Josh | CFX | 24 | May 9, 2011 10:38 |
