Ansys CFD-Post Application Error
Old   March 21, 2021, 08:51
Smile Ansys CFD-Post Application Error
Rushikesh
rushiCFD is on a distinguished road
Hello guys!
I am doing a 3D transient simulation on VAWT on ansys fluent.
1) The Solution is completed successfully but I am not able to load CFD-post. When I update the tree and click CFD-post to open it, it throws me following error: I have also attached image file.
ERROR
Error reading file 'C:\Users\rushi\Documents\fhjhj_files\dp0\FFF\Fluent\FFF.flprj':
Reason: The run contains transient output but no output files were defined.
Also When I checked the file in Fluent folder, I did find FFF.flprj. I am really not sure which "output files" the error is talking about. I am however able to load the cas.h5 files independently but it is useless since I was the transient results. I have also attached the parametric results screenshot.
2) I have not done too much of a dynamic mesh 6DOF problems in 3D. And due to this error I am not able to visualize the results. I have also uploaded the report.xml file just so that you guys can see my setup. Am I doing anything wrong? Will the turbine rotate?
Any help is really appreciated.
a report.xml matter is as follows:
<FluentXMLReport>
<version>
Fluent
Version: 3d, dp, pbns, dynamesh, rke, transient (3d, double precision, pressure-based, dynamic mesh, realizable k-epsilon, transient)
Release: 21.1.0
Title:
</version>
<Models>
Models
Model Settings
Space 3D
Time Unsteady, 2nd-Order Implicit
Viscous Realizable k-epsilon turbulence model
Wall Treatment Enhanced Wall Treatment
Heat Transfer Disabled
Solidification and Melting Disabled
Species Disabled
Coupled Dispersed Phase Disabled
NOx Pollutants Disabled
SOx Pollutants Disabled
Soot Disabled
Mercury Pollutants Disabled
Structure Disabled
Acoustics Disabled
Eulerian Wall Film Disabled
Potential/Li-ion Battery Disabled
Multiphase Disabled
</Models>
<MaterialProperties>
Material Properties
Material: air (fluid)
Property Units Method Value(s)
Density kg/m^3 constant 1.225
Cp (Specific Heat) J/(kg K) constant 1006.43
Thermal Conductivity W/(m K) constant 0.0242
Viscosity kg/(m s) constant 1.7894e-05
Molecular Weight kg/kmol constant 28.966
Thermal Expansion Coefficient K^-1 constant 0
Speed of Sound m/s none #f
Material: aluminum (solid)
Density kg/m^3 constant 2719
Cp (Specific Heat) J/(kg K) constant 871
Thermal Conductivity W/(m K) constant 202.4
</MaterialProperties>
<CellZoneConditions>
Cell Zone Conditions
Zones
name id type
outer_domain 5 fluid
turbine_domain 6 fluid
Setup Conditions
outer_domain
Condition Value
Frame Motion? no
Mesh Motion? no
turbine_domain
Condition Value
Frame Motion? no
Mesh Motion? no
</CellZoneConditions>
<BoundaryConditions>
Boundary Conditions
Zones
name id type
outlet 10 velocity-inlet
inlet 9 pressure-outlet
wall-19 19 wall
wall-18 40 wall
wall-outer_domain 7 wall
wall-turbine_domain 8 wall
blade1 11 wall
blade2 12 wall
blade3 13 wall
blade4 14 wall
shaft 15 wall
contact_region-src 16 interface
interface1-contact_region-trg 18 interface
Setup Conditions
outlet
Condition Value
Velocity Magnitude [m/s] 7.5
inlet
Condition Value
wall-19
Condition Value
Wall Motion Stationary Wall
Shear Boundary Condition No Slip
wall-18
Condition Value
wall-outer_domain
Condition Value
wall-turbine_domain
Condition Value
blade1
Condition Value
Wall Motion Moving Wall
Define wall motion relative to adjacent cell zone? yes
Apply a rotational velocity to this wall? yes
Y-Component of Rotation-Axis Direction 1
Z-Component of Rotation-Axis Direction 0
blade2
Condition Value
blade3
Condition Value
blade4
Condition Value
shaft
Condition Value
contact_region-src
Condition Value
Condition Value
</BoundaryConditions>
<SolverSettings>
Solver Settings
Equations
Equation Solved
Flow yes
Turbulence yes
Numerics
Numeric Enabled
Absolute Velocity Formulation yes
Unsteady Calculation Parameters
Number of Time Steps 200
Time Step Size [s] 0.01
Max Iterations/Time Step 15
Under-Relaxation Factors
Variable Relaxation Factor
Pressure 0.3
Density 1
Body Forces 1
Momentum 0.7
Turbulent Kinetic Energy 0.8
Turbulent Dissipation Rate 0.8
Turbulent Viscosity 1
Linear Solver
Variable Solver Type Termination Criterion Residual Reduction Tolerance
Pressure V-Cycle 0.1
X-Momentum Flexible 0.1 0.7
Y-Momentum Flexible 0.1 0.7
Z-Momentum Flexible 0.1 0.7
Turbulent Kinetic Energy Flexible 0.1 0.7
Turbulent Dissipation Rate Flexible 0.1 0.7
Pressure-Velocity Coupling
Parameter Value
Type SIMPLE
Discretization Scheme
Variable Scheme
Pressure Second Order
Momentum Second Order Upwind
Turbulent Kinetic Energy Second Order Upwind
Turbulent Dissipation Rate Second Order Upwind
Solution Limits
Quantity Limit
Minimum Absolute Pressure 1
Maximum Absolute Pressure 5e+10
Minimum Temperature 1
Maximum Temperature 5000
Minimum Turb. Kinetic Energy 1e-14
Minimum Turb. Dissipation Rate 1e-20
Maximum Turb. Viscosity Ratio 100000
</SolverSettings>
</FluentXMLReport>
rushiCFD is offline   Reply With Quote
cfd - post, dynamic meshing, transient 3d
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 13:34
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
