How to average the torque coefficient for vertical axis wind turbine? |
March 13, 2021, 09:48 |
ONESP-RO
Rep Power: 5 |
I 've carried out a simulation in Ansys Fluent of the flow around a vertical axis wind turbine. I got the Cm (torque coefficient) as a function of time, hence azimuthal angle. I have used the rotor radius as the reference length, the swept area = diameter * height. In my case height = 1 because it's a 2D simulation. Since the Cm coefficient is not constant over one rotor revolution, how to average it? because when I simply average: And The average power: (where λ is the tip speed ratio). The result is a very low Cp value. I have tried to run the simulation for several Tip speed ratios, but still, the Cp value is very low, less than 5%. (Unfortunately, I don't have experimental data to compare with). I wonder if there is something wrong with the averaging of Cm. In VAWT nomenclature, how is the Cm value averaged? I hope someone can give me insight. Thank you in advance |
August 24, 2022, 04:16 |
September 6, 2022, 15:55 |
Rep Power: 13 |
I would simply write out to a file the total torque instead of the coefficient (given that it is not clear what it is doing). Then you can average as many timestep values as you want. Regards |
Converging Diverging Nozzle with dbnsTurbFoam | Saleh Abuhanieh | OpenFOAM Running, Solving & CFD | 4 | December 13, 2019 11:26 |
Modeling a vertical axis wind turbine / Negative momentum coefficient | Felipe06 | FLUENT | 0 | January 24, 2019 18:19 |
Torque coefficient in 3D modeling of horizontal axis turbines | nima2472 | Main CFD Forum | 0 | March 28, 2017 02:15 |
Transient analysis of horizontal axis wind turbine | UmeProIITG | FLUENT | 0 | August 7, 2014 07:44 |
how to find wind turbine torque from CFD ? | siripon | Main CFD Forum | 1 | August 27, 2012 01:41 |
