Multiphase Euler-Euler Divergence
Old   March 11, 2021, 05:03
Default Multiphase Euler-Euler Divergence
Nederland
mdmtramper is on a distinguished road
Hi all!
I have a problem with running transient multiphase simulations in patient-specific aortas. I have developped a model using the three-phase euler-euler model, to model blood flow in aortas. I have applied this model on several geometries, and some of them convergence properly, however I also have 2 geometries where divergence occurs. The perculiar thing is that I run the exact same settings for a single phase models (same mesh, boundary conditions etc.) and then everything works fine (no divergence at all).
Does this problem occur more often and where should I try to find the troubles?
Kind regards,
Michelle
mdmtramper is offline   Reply With Quote
aorta, blood flow, divergence, euler-euler, multiphase
PEMFC model with FLUENT brahimchoice FLUENT 22 April 19, 2020 16:44
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 08:54
Two Phase Flow In Vertical Pipe stonepreston FLUENT 2 October 31, 2017 09:35
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
Divergence problem Smaras FLUENT 13 February 21, 2013 06:03
