March 5, 2021, 06:00 |
Text Command in UDF
Raffaele Collaro
Hi, I'm a Mechanical Engineering Student and I'm working for the final thesis. I have a problem: I want to insert a Command Line in the UDF which create a Line directly. In few words I want to do this:
surface/line-surface/new surface id/name [line-9] z0/x0=...../y0=...... How can I traslate it in UDF? Is there something in the User's Guide? |
August 22, 2022, 01:45 |
#2 | |
sina
Rep Power: 4 |
I want to use text command every iteration , Do you know how could i do it? Regards, |
August 22, 2022, 06:19 |
Alexander
Rep Power: 34 |
solution -> calculation activties -> execute commands
best regards ****************************** press LIKE if this message was helpful |
command text, line/rake, udf |
UDF and text commands | David | FLUENT | 3 | June 26, 2022 23:10 |
Divergence detected in AMG solver: k when udf loaded | google9002 | Fluent UDF and Scheme Programming | 3 | November 7, 2019 23:34 |
Fluent Radiation/porous media | Schmitt pierre-Louis | FLUENT | 26 | September 1, 2016 10:29 |
UDF for energy source which includes a text file | mrwts | Fluent UDF and Scheme Programming | 0 | September 9, 2015 17:12 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
