How to specify inlet species in Ansys Fluent 2019 R3? |
February 24, 2021, 14:46 |
omkar kedge
Rep Power: 5 |
Hello everybody, I am trying to simulate a Pre-mixed combustion in fluent. I have selected 'adiabatic' and 'c- equation' options.
I have imported a ethanol combustion Chemkin mechanism in fluent, I can see all species under the 'fluid' tab under the 'material' tab. I am using a 2-D model of a cross section of combustion chamber. I have defined one edge as inlet and the other as outlet. My question is how to define inlet species in this case?. I have selected the type as 'mass flow' inlet. But under the species tab, I can only specify the 'Progress variable'. Is it possible to specify inlet species in this case? If not, how is fluent processing the chemkin mechanism for ethanol I have inputted. Any help will be appreciated. |
GPU acceleration in Ansys Fluent | flotus1 | Hardware | 63 | May 12, 2023 03:48 |
Maintaining (P inlet) constant in Ansys Fluent | Belimane | ANSYS | 1 | January 31, 2020 06:09 |
2D Hypersonic Inlet in FLUENT - Convergence Issues | Fraisdegout | FLUENT | 6 | December 15, 2016 03:07 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
gambit in Ansys FLuent 13 | saharesobh | FLUENT | 0 | August 1, 2012 16:30 |
