What is causing strange low-velocity border at inlet? |
Rep Power: 6 ![]() |
I'm noticing some strange behavior near the inlet with my basic simulation: one 3D fluid domain, transient, inlet set with velocity of 4 m/s, laminar flow model, lateral/top/bottom walls are slip-flow (0 shear). The domain is meshed with hex cells. There are no UDFs or other settings - it's just an empty fluid domain with constant inlet velocity. From the contours, it looks like there's a border with lower-velocity for the inlet plane, and this also shows up near the inlet on the plane of fluid flow. Can anyone please advise as to what may be causing this phenomenon? Thanks! |
UDF comilation error. urgent help please | m zubair | Fluent UDF and Scheme Programming | 4 | February 10, 2019 12:19 |
serial udf to parallel udf | radioss | Fluent UDF and Scheme Programming | 10 | January 19, 2019 09:56 |
Defined inlet velocity is different with inlet velocity on CFX post | jonpewpew | CFX | 2 | November 2, 2017 17:40 |
Setting Density for Velocity Inlet Face | arkie87 | FLUENT | 0 | November 7, 2012 16:15 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
