Taylor Couette flow symmetry case
Old   February 23, 2021, 13:38
Question Taylor Couette flow symmetry case
Mahmouddixx is on a distinguished road
I am working on Taylor Couette flow between concentric cylinders and the results are correct for the full case. however, I wanted to do symmetry case to improve the mesh. I have used periodic boundary condition +match control for the air and I got good results. However, when I try to add the cylinders in the case, I get wrong results. I don't know what am I doing wrong.
I am using Ansys 19 R2. Fluent
Thank you in advance
Mahmouddixx is offline   Reply With Quote
concentric cylinders, periodic boundary, symmetry, taylor couette flow
Simulation of a chimney with heat in open atmosphere Jurado OpenFOAM Running, Solving & CFD 9 December 18, 2020 08:35
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 16:13
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 18:02
Review: Reversed flow CRT FLUENT 1 May 7, 2018 06:36
Channel flow with symmetry Plane not symmetric Hillie OpenFOAM Running, Solving & CFD 0 May 19, 2017 23:32
