February 17, 2021, 03:49 |
Exporting an area as a profile - Fluent
I would like to export the heat flow over an area as a PROFILE from a steady state 3D simulation. I load this Profile into another steady state 3D simulation. I would like to multiply the values for the heat flow from the PROFILE using a scalar. For this I would like to create an expression that contains the values of the profile. In the Ansys help page you can see that the profile can be used when writing the expression. I attached an image. On the image you can see that, I don't have this tab. Does anyone have an idea how to solve it? Thanks for help! Many Greeting |
February 19, 2021, 03:39 |
The problem is solved by using ANSYS R2021. |
fluent - udf |
Face area magnitude inconsistency when exporting | ReeKo | FLUENT | 6 | February 21, 2021 21:10 |
Log Profile UDF for FLUENT | sariug | Fluent UDF and Scheme Programming | 2 | August 15, 2016 06:58 |
Fully developed temperature profile for laminar/turbulent flow in FLUENT | raghu.tejaswi | FLUENT | 10 | November 7, 2012 10:57 |
Exporting structured mesh from ICEMCFD to Fluent? | jeevan kumar | FLUENT | 1 | January 23, 2012 12:21 |
Ansys FLUENT UDF - Velocity profile (of known values) across edge / surface | emmkell | Fluent UDF and Scheme Programming | 2 | October 21, 2011 14:12 |
