Computing local DPM volume fraction using DPM in Flunet |
February 16, 2021, 01:57 |
Anshuman Sinha
Rep Power: 8 |
I am simulating a gas-driven flow in a water fluid column. I need to model the drag force experienced by the individual bubbles in the column. Since the bubbles are surrounded by many other bubbles and hence the local force experienced by an individual bubble is a function of void fraction and the flow field around the bubble.
I need to implement a UDF for drag modification so that it can incapsulate the above-mentioned modifications. Currently, I'm modeling in Fluent using Multiphase-DPM modeling with VOF formulation. |
dpm, multiphase, udf |
interFoam wave propagation and explosion of Courant number and residuals | ChiaraViola | OpenFOAM Running, Solving & CFD | 1 | June 26, 2019 06:36 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
interDyMFoam - change in volume fraction | gopala | OpenFOAM Running, Solving & CFD | 0 | April 27, 2009 11:46 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 22:14 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
