Kanami
Rep Power: 0 ![]() |
Hello, everyone.
I am new to dealing with fluent. Since no one in my lab has done numerical analysis in the past, I am having a lot of trouble in proceeding with the analysis. I am doing a numerical analysis of the inside of the combustion chamber of a hybrid rocket in 2D. (Please refer to the picture for the model. The model is for an axis.) I am assuming that the oxidizer (oxygen) flows out of the inlet on the right, and the fuel (kerosene air mixture) melts and flows out of the upper and lower inlets. (1) I am not sure whether to use the fuel inflow as velocity or mass flow. I have calculated the flux and mass flow rate for the fuel based on the fuel recession rate, but which should I use? (2) When I run the numerical analysis with the fuel as flow velocity, the combustion reaction does not occur properly. What should I do to set the analysis conditions? I would like to thank everybody in advance. Kanami Last edited by Caramel; February 15, 2021 at 22:59. |
ansys, chamber, fluent, hybrid rocket |
CFD Simulation of a Rocket Engine Nozzle: Divergence Issue (Want to see nozzle plume) | VinayakDesh | FLUENT | 4 | February 2, 2022 20:57 |
Number of Particles distribution in a chamber using flow simulation - how? | teleguy | FloEFD, FloWorks & FloTHERM | 0 | January 24, 2021 11:27 |
SU2 development for combustion in Hybrid Rocket Motors | rdbisme | SU2 | 0 | November 12, 2015 14:43 |
Simulation of air flow in a chamber | Issa | CFX | 3 | November 23, 2009 17:16 |
hybrid rocket combustion? | PattiMichelle | OpenFOAM | 0 | November 5, 2009 11:33 |
