remove particle at interface fluent udf
Old   February 10, 2021, 02:42
Default remove particle at interface fluent udf
Joonwoo Park
Joonwoo is on a distinguished road
I want to simulate the bubble column problem (VOF+DPM). In the simulation, I want to eliminate the bubble at the interface. Thus, I should make a udf in fluent. From the other question, I already made a udf as follows.
#include "udf.h"
#include "dpm.h"
DEFINE_DPM_SCALAR_UPDATE(stream_index, c, t, initialize, p)
#if PARALLEL
Thread *phase_t = THREAD_SUB_THREAD(t, 1);
if (C_VOF(c, phase_t) >= 0.5)
p->stream_index = -1;
#endif
This function is compiled well, but the problem is not working in my simulation. I want to eliminate each bubble at the interface. However, each bubble is deleted at outlet. How can I define the remove particle at interface using udf?
Best regards,
Joonwoo
Joonwoo is offline   Reply With Quote
dpm, fluent, particle, remove, udf
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
How to solve UDF compilation problems in Fluent. pakk Fluent UDF and Scheme Programming 16 September 10, 2018 03:48
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
