February 3, 2021, 18:55 |
Loading energy source from data file
Aidan Shek
I am wishing to find the steady state temperature of a solid undergoing cooling.
I have a file in .dat format with a table of element numbers of solid and the heat generation rate at the element I was wondering is there a way to load this table of data into fluent so that the solid undergoing cooling would have the heat source at each of the elements? Thanks |
cooling, fluent, heat transfer, load, source |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 03:04 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
