Mukesh
Rep Power: 0 ![]() |
I am trying to run the model in fluent solver. and I tried to get the better result with convergence. I tried both steady and transient phase. My first problem is, its not converging and when i try transient phase its shows an error " fl point exception" and I setup the "escaped mass" to track the particle in steady state but when I run the model, In each iteration I am getting the zero value.
also can you recommend me the best parameter in fluent that best fit for this model. I have a nozzle in which one side of the nozzle is attached with incoming flow and the other side of the nozzle is attached to the hot rotating tube. The incoming flow in the nozzle is nitrogen and powder. |
Solution to Quasi 1D converging-diverging nozzle problem (euler equations) blowing up | sangeet | Main CFD Forum | 12 | April 24, 2020 19:33 |
Problem running Solution in CFX | JMSFerrari | CFX | 1 | September 23, 2019 05:44 |
ESI-CFD Problem with initialization from previous solution | Anil619 | Main CFD Forum | 0 | April 25, 2017 16:36 |
Problem with pimpleDyMFoam: Initialise steady state solution | Lancester | OpenFOAM Running, Solving & CFD | 2 | September 29, 2015 09:49 |
Naca 0012 (compressible and inviscid) flow convergence problem | bipulsaha | FLUENT | 1 | July 6, 2011 07:51 |
