How to delete wrong wall?
Old   January 22, 2021, 10:58
Default How to delete wrong wall?
Jaeuk Lee
GSWagain is on a distinguished road
Hello. I'm generating mesh by using ANSYS ICEM.
Tank is composed of two parts, fluid and solid part.
I made wall part for outside of the tank(outside of solid part).
Then, inner surfaces become inside wall of the tank.
Now, there is problem... The problem is that some parts were recognized as wall in ANSYS Fluent..
You can see what I mean in the attached photo. I want to remove wrong wall. How can I fix it? Thanks in advance
GSWagain is offline   Reply With Quote
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
[mesh manipulation] mergeMeshes problem Attesz OpenFOAM Meshing & Mesh Conversion 3 July 29, 2015 05:15
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh Shoonya OpenFOAM Meshing & Mesh Conversion 11 January 20, 2012 07:23
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 13:11
How to delete the wall? Suvash Saha FLUENT 17 December 10, 2009 03:33
