Text Command for creating a surface?
Old   January 21, 2021, 05:52
Default Text Command for creating a surface?
yadhu
beastmaster is on a distinguished road
Hello guys , i am trying to create a plane surface and trying to write the temperature profile on that surface,
these are my codes for that
(ti-menu-load-string (format #f "surface plane-surf-aligned ooooo~a wall-sink 0"))
(ti-menu-load-string (format #f "file write-profile test.pro plane-13 () total-temperature () " ))\n
the plane(plane-13) i am trying to create is aligned to wall sink, and at coordinate z=0, i am getting a error but, can anyone help me in this?
regards
beastmaster is offline   Reply With Quote
Old   January 21, 2021, 06:29
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
find TUI command to create plane you want and put it inside
(ti-menu-load-string (format #f "   "))
if you want to put any variable value inside the command you can use this approach
(ti-menu-load-string (format #f "  ~a " variable))
as a result value of variable will be executed
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   January 21, 2021, 08:52
yadhu
Thanks for helping me out , but I couldn't find the TUI command to create a surface (say plane 12) aligned To a wall(say wall-1) at position z=0, if possible can you tell me the command?
Regards
Old   January 21, 2021, 22:43
Alexander
type word "surface" in fluent console, press enter
you will see the list of available options
delete-surface          multiple-zone-surfaces  quadric-slice
group-surfaces          partition-surface       rake-surface
imprint-surface         plane                   rename-surface
type "plane-surf-aligned " press enter
it will ask surface name
ans so on, this is a way for you to make this TUI command
except plane-surf-aligned you may try to use other methods to create plan if needed
best regards
Old   January 23, 2021, 10:45
yadhu
I tried this out, it really worked, but is there any way to write all of this in one line command? I'm trying to write plane surf aligned function, aligned to surface wall sink, with distance 5
Old   January 23, 2021, 14:38
pakk will become famous soon enough
Once you find the correct sequence of words, you can just put them on one line.
pakk is offline   Reply With Quote
[snappyHexMesh] Surface triangulation using snappyHexMesh shaileshbg OpenFOAM Meshing & Mesh Conversion 4 October 17, 2019 05:42
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[DesignModeler] Imported 3D curve from text but cant generate surface avidash ANSYS Meshing & Geometry 0 May 21, 2015 07:37
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
