how to write xy plot for every design point?
Old   January 20, 2021, 07:47
Default how to write xy plot for every design point?
yadhu
beastmaster is on a distinguished road
how do i write xy plot for temperature for every design point without opening fluent, is there any way to do it?,any help would be appreciated
Regards
beastmaster is offline   Reply With Quote
Old   January 20, 2021, 12:18
vav noon
vavnoon is on a distinguished road
Hi my friend
I think you can use the following path:
Solution > Monitors > report files > new > new > surface report > vertex average
Then you can choose your desired field variable (here temperature) at your desired point.
Then select create > report file and finally you can chane the frequency that you want to save data.
After calculation, you can open the file using notepad++.
Regards
vavnoon is offline   Reply With Quote
Old   January 20, 2021, 12:30
yadhu
Originally Posted by vavnoon View Post
Hi my friend
Regards
Vertex average gives temperature profile?
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" ds4719 Main CFD Forum 14 February 18, 2022 19:05
ANSYS Freezing on Parameters Design Point Fluent.novice FLUENT 2 January 13, 2021 04:24
Workbench in batch mode with parametric study (design point) Veronique Pe ANSYS 0 June 1, 2016 04:56
How to request cfx to write variables at a point? Uday CFX 1 February 6, 2006 00:42
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 16:56
