Automatically writing of temperature profile?
Old   January 20, 2021, 01:21
Default Automatically writing of temperature profile?
yadhu
beastmaster is on a distinguished road
hello guys, i am trying to simulate flow across a heat sink, im using a parameter table for changing the geometry of the heat sink, i want to write out the temperature profile at the mid plane of the heat sink, is there any way to do this automatically, as far as i have searched, it can only be done manually, any help or guidance would be appreciated
Regards
beastmaster is offline   Reply With Quote
Old   January 20, 2021, 03:21
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
what do you mean under temperature profile?
you can make monitor and write data to file
what is you manual way to define temperature profile?
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   January 20, 2021, 03:28
yadhu
Usually after the solving we manually go to cell zone condition and write profile, instead of that is there any way to write the profile of temperature automatically, like giving a command or something?
Old   January 20, 2021, 04:08
Alexander
Usually, It is possible to do using TUI commands, there are ways to execute these commands automatically as well
but to help you, you should describe the full way, you are defining that profile, which you are talking about
best regards
Old   January 20, 2021, 04:17
yadhu
I am trying to do 500 simulations of flow across a heat sink, I am using parameter table for this, I want to write a temperature profile on a mid plans of the heat sink, is there any way to do it automatically like without opening fluent every time?
Old   January 20, 2021, 07:27
yadhu
this is the write profile i was talking about, this had to be done manually right? i was asking if there is any way to do this process without opening fluent after every design point in my data table is solved
Old   January 21, 2021, 02:25
Alexander
you may make journal file with this code and execute it after each design point
(ti-menu-load-string (format #f "file write-profile test.pro plane-13 () total-temperature () " ))
best regards
Old   January 21, 2021, 02:28
yadhu
So after the code in journal file at the end I'll add this?
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? EternalSeekerX SU2 3 October 9, 2020 19:28
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Temperature profile with isothermal steady state simulation Procyon CFX 6 November 11, 2019 13:06
Help please! UDF for Temperature profile in 3D subhankar_bhandari Fluent UDF and Scheme Programming 2 August 16, 2010 09:37
