January 19, 2021, 04:20 |
the position of mass sources will be added
Cheng CHEN
Rep Power: 6 |
Hi all
I want to know where the mass sources will be added in a liquid-gas two phase flow when VOF model is used? In my case, there is a surfactant in the liquid that is similar to ethanol. -- If you have only one species in your problem, you can simply define a Mass source for that species. The units for the mass source are . In the continuity equation (Equation 1–1 in the Theory Guide), the defined mass source will appear in the Sm term. -- Above is from the ANSYS help ,so the species refers to the liquid/gas, or to the surfactant I have added. Best regards cheng chen |
Mass flow imbalance for a specific mesh position | Sasquatch | CFX | 4 | October 12, 2016 22:58 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
Mass sources | Nikolaos | FLOW-3D | 1 | January 10, 2009 01:22 |
Mass sources - help! | Emmanuel Resch | Siemens | 11 | May 29, 2008 11:20 |
Calculation of added mass in viscous flow | kharati | Main CFD Forum | 2 | February 1, 2006 01:28 |
