January 19, 2021, 00:05 |
Melting and solidification model
Ahmed
Rep Power: 7 |
Hi guys
I am using the melting and solidification model to simulate the melting of pcm inside water tank The boundary conditions defined are the temp of the heating pipes at the bottom of the tank (surface temp defined as function of time ) Both water and PCM was defined as Boussinesq water properties are constant ( didn't define latent heat or solidus or liquidus temp as water won't change phase ) PCM properties are constant .. solidus and liquidus temp = 41 C The problem is As shown in photos , the results is going smoothly and correct until suddenly it goes up severly and became unlogical .. so what may cause this ? |
January 19, 2021, 12:29 |
Marat
Rep Power: 7 |
Hey. try to use graphs for the average volume. Because it is not logical to look at the result on the surface. The graph is presented as an example and nothing else.
VOF and Solidification and Melting model: Melting of solid block | ShubhCFD | FLUENT | 1 | June 15, 2020 09:53 |
Verification of melting and solidification three phase model | kuechenrole | OpenFOAM Verification & Validation | 4 | May 10, 2020 12:47 |
ice melting simulation combine Solidification and VOF model | wuxuetianzi | FLUENT | 3 | November 18, 2018 22:03 |
melting or solidification model in CFX | jasonchang | CFX | 5 | January 31, 2018 07:33 |
Question about solidification and melting model | aestas | FLUENT | 0 | November 8, 2015 21:32 |
