How to control number of particles entering the domain with DPM model
Old   January 18, 2021, 08:14
Default How to control number of particles entering the domain with DPM model
Dnyanesh Mirikar
DnyanMiri is on a distinguished road
I have the mass of droplets injected, the duration for it is injected, and diameter range, mean diameter for rosin-rammler distribution.
How can I control the number of particles injected in the domain for a given time period?
From mass and density, I can calculate the total volume of droplets injected. If I divide it by volume of the droplet of the mean diameter, I'll get the number of droplets injected, right?
Now in unsteady simulations, fluent is injecting particles at every time step. And these numbers are way greater than what I'm getting from the above calculations.
What mistakes I'm making? Thanks in advance.
DnyanMiri is offline   Reply With Quote
Old   January 18, 2021, 13:24
pakk will become famous soon enough
I don't know, but I do know it would help a lot to show your calculation. If it's wrong, somebody might set the mistake.
pakk is offline   Reply With Quote
Old   March 2, 2021, 05:32
ahmed elbanna
ahmed banna is on a distinguished road
recommend you refer to documentation published by Ansys Fluent including the theory guide and user guide as they correlate the different models with the recommended operating range.
i have used DPM to simulate dilute flow at low ST you can refer
An experimental and theoretical study on particles-in-air behavior characterization at different particles loading and turbulence modulation
https://doi.org/10.1016/j.aej.2019.04.002
ahmed banna is offline   Reply With Quote
diameter distribution, dpm, mass flow, particle injection
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
[blockMesh] --> foam fatal error: lillo763 OpenFOAM Meshing & Mesh Conversion 0 March 5, 2014 11:27
convergenceof natural convection prob. in cfx cpkewat CFX 15 January 31, 2014 07:29
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
