January 16, 2021, 23:49 |
Command Line Operations in Fluent
Aqib Aziz
Rep Power: 6 |
Hello everyone!
I am learning fluent and I want to learn using command line operations in fluent. If you know about this operations then please guide me how can I learn it? You can give me suggestions about sources where I can find some tutorials about it. Your cooperation in this regard is highly appreciated. Thanks! |
January 17, 2021, 02:51 |
Rep Power: 27 |
The first source to look at is the manual. What are you missing there?
January 18, 2021, 03:04 |
Alexander
Rep Power: 34 |
what do you mean under command line operations ?
TUI commands? almost everything is possible to make in FLuent interface without any TUI commands you may investigate available TUI commands by yourself go to fluent console, press enter, you will see the list of available options first you will see: Code:
adapt/ mesh/ solve/ define/ parallel/ surface/ display/ plot/ views/ exit report/ file/ server/ Code:
adapt-boundary-cells exchange-marks mark-inout-hexahedron adapt-to-gradients fill-crsn-register mark-inout-iso-range adapt-to-ref-lev free-parents mark-inout-sphere ...
best regards ****************************** press LIKE if this message was helpful |
January 18, 2021, 06:43 |
Thanks
Aqib Aziz
Rep Power: 6 |
Thank you so much guys for your kind response. I got it 😊
command line operations |
CFX vs. FLUENT | turbo | CFX | 4 | April 13, 2021 09:08 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 04:22 |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 07:22 |
batch mode fluent - beginner | CompIng | FLUENT | 1 | November 30, 2015 12:48 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 17:48 |
