Unable to get positive lift for ornithopter analysis |
January 16, 2021, 11:20 |
Rep Power: 6 |
I've been trying to perform a CFD analysis of a flapping wing. Please view the attached images. I have taken a flat rectangular wing inclined at an angle of 45d to the wingspan-axis and 15d to the fuselage-axis. I created a cylinder around it so that the cylinder rotates and inturn the wing rotates. I created a cuboidal part that acts as a wind tunnel. I gave a velocity of 2m/s and performed a transient CFD analysis and measured the lift after every time step. I'm using the k-e, RNG, swirl dominated flow with scalable wall function. The problem is I'm getting negative cl and inturn a negative lift force. Can you please help me figure out why I'm getting a negative lift and how to make it positive? I first created a boolean between the wing and the rotating wall and then a boolean (while preserving body) between the wind tunnel and the rotating wall. UPDATE: The lift is positive when I do a static analysis at -15d and 60d dihedral. But as soon as a start the mesh motion the lift goes negative! https://youtu.be/jM-M0eLhM_4 Last edited by Nishanth; January 17, 2021 at 08:31. |
Global stability Analysis of flow around a cylinder: All eigenvalues positive | Werne | Main CFD Forum | 8 | February 27, 2021 16:57 |
Unable to get positive lift for ornithopter analysis | Nishanth | Main CFD Forum | 2 | January 17, 2021 03:01 |
How to calculate lift, drag and lift distribution in Star CCM+? | israelcasillas94 | STAR-CCM+ | 4 | November 6, 2020 09:35 |
Positive Lift force for a vehicle ? | mansouri | FLUENT | 1 | January 20, 2015 08:58 |
unable to obtain residual and lift coefficient convergence in SU2 | deeps | SU2 | 3 | December 27, 2013 02:58 |
