error abnormal exit node 999999
Old   January 16, 2021, 07:29
Default error abnormal exit node 999999
Spiros Kouzoupis
Spiros Kouzoupis is on a distinguished road
[mpiexec@] ..\\hydra\\pm\\pmiserv\\pmiserv_cb.c (863): connection to proxy 0 at host failed
[mpiexec@] ..\\hydra\\tools\\demux\\demux_select.c (103): callback returned error status
[mpiexec@] ..\\hydra\\pm\\pmiserv\\pmiserv_pmci.c (520): error waiting for event
[mpiexec@] ..\\hydra\\ui\\mpich\\mpiexec.c (1149): process manager error waiting for completion
Why i have this problem? recently i turned off hyperthreading, maybe this is it? Also i had this problem with internet on and off. is because of the MPI? my transcript file says i have intel MPI. Every night i have this problem.
Spiros Kouzoupis is offline   Reply With Quote
Old   January 19, 2021, 14:46
s a
sactronin is on a distinguished road
It happens because the computer disconnects from the internet during fluent calculation process. Which version of fluent are you using?
sactronin is offline   Reply With Quote
Old   January 19, 2021, 19:24
Spiros Kouzoupis
But it happened also without ethernet. 2020 r2.
fluent
mpiexec- error abnormal exit node 999999 Spiros Kouzoupis ANSYS 0 January 16, 2021 07:15
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
999999 (../../src/mpsystem.c@1123):mpt_read: failed:errno = 11 UDS_rambler FLUENT 2 November 22, 2011 10:46
