continuity-convergence problems during mesh independence study |
Rep Power: 0 ![]() |
Dear all,
I'm quite new to Fluent and this is my first thread. I hope someone can help me. I’m facing continuity-convergence problems in my steady k-w SST simulation with refined meshes. I'm trying to simulate a flow with one inlet and ten outlets (one main outlet and 9 smaller outlets, see picture Initial_Meshing). The flow rate at the inlet and the main outlet is known and I want to examine the distribution between the 9 smaller outlets. My initial simulation, with a coarse mesh (750.000 nodes, 1.750.000 elements) converged for first and second order discretization (see picture CoarseMesh_SecondOrder_ResidualPlot). For a mesh independence study I used the same settings with refined meshes (1.050.000 nodes, 2.770.000 elements and 1.500.000 nodes, 4.560.000 elements) . With the refined meshes, the simulation only converged with first order discretization but not with second order (see picture RefinedMesh_SecondOrder_ResidualPlot). I monitored the flow at the outlets. The monitors showed a constant, almost oscillating, change in the outflow (see picture RefinedMesh_SecondOrder_MassFlowMonitor). This was not the case in the initial simulation with the coarse mesh. I'm unsing the following settings with a tet-Mesh. For the flow I've calculated reynolds numbers of about 4000 at the inlet, about 3000 at the main outlet and about 1000 at the small outlets. Model: k-w-SST, with Low Re correction Boundary Conditions Inlet: Mass-Flow-Inlet Main Outlet: Mass- Flow- Outlet Small Outlets: Pressure Outlet with 0 gauge pressure Methods: Scheme: Coupled Gradient: Green-Gaus Node Based Pressure: PRESTO! Momentum: Second Order Upwind Turbulent Kinetic Energy: Second Order Upwind Specific Dissipation Rate: Second Order Upwind with pseudo transient setting Controls: Pressure: 0,2 Momentum: 0,3 Density: 1 Body Forces: 1 Turbulent Kinetic Energy: 0,75 Specific Dissipation Rate: 0,75 Turbulent Viscosity: 1 So far I've tried to: - lower the relaxation factors - use differnt discretization methods - use differnt initializations I really hope someone can help me. Best regards, Peter Last edited by cola93; March 31, 2021 at 08:32. |
convergence problems, mesh independence study, sst k-omega |
Mesh independence study for transient simulation | snejball91 | CFX | 9 | November 17, 2022 01:12 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[blockMesh] mesh causing problems with convergence | Tetragramm | OpenFOAM Meshing & Mesh Conversion | 0 | September 22, 2012 16:00 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
