Pcm melting, multiphase
Old   January 7, 2021, 16:47
Default Pcm melting, multiphase
mehran
mehran-b is on a distinguished road
Hi
I was able to simulate the project of melting the pcm in a tube that is heated by both the tube and the battery, only the pcm melts faster than the actual laboratory conditions. Especially from the side of the chamber tube. What should I do to reduce the melting rate?
mehran-b is offline   Reply With Quote
Old   January 8, 2021, 01:07
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
if the pcm melts faster than the actual laboratory conditions, it means pcm gets more energy, decrease it
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   January 8, 2021, 07:28
mehran
how can I decrease it?
Old   January 8, 2021, 07:48
Alexander
change heat source
or/and change material properties
or/and add contact heat resistance
or/and add convection/radiation
or/and take into account phase transfer effects
best regards
solidification and melting with VOF: how to sink solid PCM as it melts? sakil2k3 FLUENT 32 November 15, 2019 07:27
melting + vof modeeling for PCM in air taw FLUENT 2 August 24, 2018 01:21
PCM melting inside the Al cavity shoxan FLUENT 1 August 9, 2018 03:12
melting of a pcm flex00 FLUENT 2 April 8, 2013 14:33
melting PCM maherm FLUENT 0 June 19, 2012 10:44
