January 7, 2021, 04:47 |
Velocity slip and temperature jump UDF
zhangdongjie
Rep Power: 5 |
I'm simulating a nozzle with rarefied gas. Its kn number is very large. First order slip and temperature jump must be added. I use Maxwell slip equation to write UDF, but I don't know where UDF should be loaded. I look up the data. The sliding speed can be loaded into the shear stress, so where is the temperature jump loaded? Is it loaded directly into the wall temperature? But my wall temperature is fixed at 300K.
If anyone has a compiled UDF file, can you send me one? Thank you very much.1248385182@qq.com |
October 15, 2021, 04:17 |
Xin Zhang
Hi,dongjie. I'm working on a slip wall simulation too. I also use Maxwell slip equation to write UDF, and I am trying to define the wall shear stress for the "Specified Shear" in Wall boundary condition. But my calculation results turns out wrong. I want to know if your UDF works well? How do you define the slip boundary in your UDF?
Thanks a lot. |
How to set slip velocity and temperature jump | awuunity | CFX | 10 | July 2, 2018 09:40 |
Implementation of maxwell slip velocity and Temperature jump with openfoam | yassepid | OpenFOAM | 2 | June 28, 2016 08:05 |
UDF for slip velocity at wall and temperature jump near wall | mkpm | Fluent UDF and Scheme Programming | 5 | May 19, 2016 03:10 |
2-d axisymmetric microtube flow with velocity slip and temperature jump b.c. | dayashankar | FLUENT | 1 | May 18, 2016 22:45 |
UDF slip and temperature jump from IFRT | abir | Fluent UDF and Scheme Programming | 1 | July 30, 2012 06:44 |
