January 6, 2021, 13:17 |
CD nozzle flow divergence
Hamish
Rep Power: 5 |
I am trying to reproduce a paper that modeled an argon arc jet. However, when just trying to run a base flow (no heat source at constrictor to mimic the arc) I get divergence almost immediately and temperature and pressure go to their limits.
The model conditions: Density-based solver 2D - Axisymmetric condition Steady Energy equation On Laminar flow The fluid is Argon using ideal gas for density and Sutherland for viscosity Inlet = Mass flow inlet at 60 mg/s Outlet = Pressure-outlet at 0 Pa Operating pressure is 0 Pa Walls are no-slip I think the issue is with the outlet conditions. The paper doesn't give an outlet pressure, they extrapolate it from the inner grid. My understanding is in compressible-flows in Fluent you can't use this outflow condition. However, the flow should be supersonic at the outlet. Also, no information is given on inlet pressure, so I have set it to 0Pa. I assume this isn't accurate. Any advice on where I am going wrong and where to improve the simulation? |
January 6, 2021, 16:58 |
Lorenzo Galieti
Rep Power: 12 |
Just think about it man: you are giving at the outlet 0 Pascal, and your operating pressure is also 0, so you are really setting the physical pressure to zero. No wonder everything explodes
January 7, 2021, 02:56 |
Alexander
Rep Power: 34 |
from my point of view:
1. in inlet mass flow boundary you should put the pressure of chamber 2. you may patch chamber with expected pressure 3. you should resolve better boundary layers 4. you may add air domain after the nozzle (extend your domain) so you may use pressure outlet boundary condition there with pressure 0 (in boundary condition you want to put 0 in case your operating pressure is 101315, or otherwise)
best regards ****************************** press LIKE if this message was helpful |
convergent-divergent, divergence of temperature, nozzle flow |
PEMFC model with FLUENT | brahimchoice | FLUENT | 22 | April 19, 2020 16:44 |
Nozzle Flow - Divergence Problem | Ijaz | FLUENT | 9 | January 11, 2014 05:36 |
reversed flow in over-expanded supersonic nozzle | imnull | FLUENT | 0 | March 28, 2013 11:48 |
Divergence problem | Smaras | FLUENT | 13 | February 21, 2013 06:03 |
compressible flow in a counterflow nozzle | d.vamsidhar | FLUENT | 0 | November 24, 2005 02:45 |
