January 3, 2021, 17:29 |
Water circuit inside air enclosure
Manuel
Rep Power: 5 |
I would like to simulate inside an air enclosure a water circuit (with inlet and outlet inside the enclosure) in order to determine it's passive cooling. So far I have tried to substract from the enclosure the water circuit (while keeping the tool body) as a result I will end with 2 components and 3 volumetric regions: -Volumetric region referring to the water circuit inside the air enclosure as an internal volumetric region -Volumetric region referring to the enclosure -Volumetric region referring to the water circuit I am not fully sure on how to deal with that first volumetric region, and so far all the attempts I have tried have ended up in error Thanks in advance for any hint |
January 4, 2021, 00:16 |
#2 | |
Alexander
Rep Power: 34 |
What do you mean under "deal with" ? What did you try to do? What kind of error did you get? Are you talking about mesh?
best regards ****************************** press LIKE if this message was helpful |
January 4, 2021, 02:54 |
#3 | |
Manuel
Rep Power: 5 |
I did both (delete and select it as dead) but I'd end up with "failed to allocate" error, which I'm surprised considering it's a small geometry. |
cross flow, fluent, heat exchange, water and air |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
interFoam, can I just set velocity of water if the inlet boundary has air and water m | tidal | OpenFOAM | 4 | October 19, 2021 09:43 |
Coupled Heat and Mass Transfer | Mecroob | OpenFOAM Running, Solving & CFD | 1 | July 12, 2020 19:24 |
compressibleInterFoam case – a flat wall air cavity filling up with water | Zeppo | OpenFOAM Running, Solving & CFD | 0 | October 3, 2015 10:01 |
air into box filled with water, outflow for water at bottom | dieterdanger | Fluent Multiphase | 0 | July 16, 2015 16:11 |
