Not getting convergence using Explicit spatial and Transient formulation in Fluent.
Old   January 1, 2021, 19:37
Default Not getting convergence using Explicit spatial and Transient formulation in Fluent.
Punsa
Patelp1996 is on a distinguished road
I am trying to simulate the shock wave which is coming out from the shock tube from one of it's open(to ambient) end using the inviscid Model. For that I created a 3D Model and the enclosure is divided into several parts for proper meshing(Picture 1). Also attached some pictures with meshing(Pictures 2,3,4). Non reflective Pressure boundary conditions are applied at the surfaces of the ambient and the Pressure inlet at the other close end(Left end of driver side) of the shock tube.
So, I had tried with different courant Number starting from 1 with the first order and second order upwind but in both the case the y and z velocity is not converging. I attaching the graph below(Picture 5). This is generated with second order upwind and courant 1 and if I use first order upwind then those oscillation are minimized and gives a smooth graph but still the y and z velocity are not converging with explicit spatial and transient formulation and even residuals did not go below 10^ (-1).
Can anyone tell me where I had done a mistake or what I have to do for convergence??
Patelp1996 is offline   Reply With Quote
Old   January 1, 2021, 19:41
Default Some Missing Data
Punsa
Here I am attaching the picture of the Pressure contours on the XY plane of the geometry.
Thank You.
Regards,
Prem.
divergence, explicit solver, shock tube, shock waves
Setting a transient convergence criterion giovannibonino OpenFOAM Running, Solving & CFD 0 December 23, 2016 07:17
Transient heat flux changing in spatial coortinate shahpar73 CFX 5 September 4, 2016 19:56
when to use totally explicit schemes or dual time-stepping in transient flow? dli Main CFD Forum 7 March 9, 2016 20:43
spatial and transient B.C. using UDF Park FLUENT 0 April 28, 2005 22:32
