January 1, 2021, 09:19 |
mixing plane and Particle tracks error
Darius
Rep Power: 5 |
Hello and happy new year to everyone,
I am trying to simulate Particle tracks in a Rotor-Stator setup where I use the turbo mixing plane model to connect the rotating and the steady mixing plane. My problem is, that every time I want to calculate either particle tracks or streamlines I get an error, mostly this one: PHP Code:
I have also tested with the two other turbo-models pitch-scale and no-pitch-scale, here the same error appears. However, if I do not select any special option for the interface in the turbo-create menu, I can generate particle tracks or streamlines without problems. If someone has an idea why this is happening, I am grateful for any help. Best regards Darius |
mixing-plane, postprocessing |
CFD Post Batch File Error | zacko | CFX | 0 | January 14, 2020 05:05 |
particle number/mass flux across a plane | cfdopenfoam | OpenFOAM Running, Solving & CFD | 1 | May 19, 2017 18:32 |
particles leave domain | Steffen595 | CFX | 9 | March 7, 2016 16:19 |
Monitor particle diameter and its frequency at a plane | Lola27 | STAR-CCM+ | 1 | December 19, 2013 05:33 |
Particle Tracks - In a plane? | varunrajendra | FLUENT | 1 | September 23, 2009 09:08 |
