Axial Fan Simulation Inside a Agriculture Machine |
December 30, 2020, 10:10 |
Hello.
I am trying to simulate the flow of air inside a machine in Ansys Fluent, for my master's thesis. The particularity is that the air is sucked in by an axial fan, and I intend to observe its flow until the machine exits. If I assume that the air enters other than with the fan, I get good results. But if you do the fan simulation, the results are bad. I saw several tutorials but most of them are really simple, nothing to do with the "real life". The machine has a main body (called case), fan (that i have substracted from the rotating body) and the rotating body. I'm doing mesh motion with k-epsilon model in transient mode. Any help is very appreciated. Thank you. |
axial fan, fluent |
Axial fan simulation | shaheen | FLUENT | 3 | September 3, 2014 02:37 |
Fan simulation with inlet and outlet duct for finding fan curve | chaudhry_hashim | FLUENT | 0 | August 6, 2014 10:49 |
Fan simulation divergence | ayothicfd | CFX | 18 | July 20, 2012 05:53 |
Axial fan or blower cooling a hot object with recirculation | mariconeagles96 | CFX | 4 | April 18, 2012 08:41 |
flow simulation across a small fan | jane luo | Main CFD Forum | 15 | April 12, 2004 17:49 |
