December 28, 2020, 23:05 |
question about ANSYS Fluent Execute Commands
I have a transient CFD case in which 5 zones need to be activated and deactivated in a sequential way. To establish initial condition, a steady-state case is first simulated in which the 1st zone is deactivated and other 4 zones are activated. During the transient simulation: at time step=100, 1st zone is activated, and 2nd zone is deactivated. at time step=200, 2nd zone is activated, and 3rd zone is deactivated. at time step=300, 3rd zone is activated, and 4th zone is deactivated. at time step=400, 4th zone is activated, and 5th zone is deactivated. As you can see, the 5 door zones are activated and deactivated in a sequential way and each door zone is activated/deactivated only one time. But in Execute Commands, it seems that I can only specify the calculation activities in a repetitive way, i.e. every * iterations or every * time steps. Could you please kindly suggest if there are any ways in Fluent to handle this CFD case or I have to do it manually? Thanks, jhz |
December 29, 2020, 02:19 |
Alexander
Rep Power: 34 |
you may put "if statement condition" to check time moment
cause seems like you know open/close time moments from the very beginning
best regards ****************************** press LIKE if this message was helpful |
Fluent Execute Commands: Syntax for return | pisykl | FLUENT | 0 | June 16, 2016 20:45 |
Ansys structural and fluent for FSI | assafwei | FLUENT | 1 | June 20, 2014 10:56 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 02:00 |
Results are different for Ansys Fluent 14.0 and Fluent 6.3 | syavash | Fluent UDF and Scheme Programming | 1 | February 17, 2013 01:09 |
[GAMBIT] 3.5 years overtake by Ansys: Where are the enhancements in grid generation | Volker P. | ANSYS Meshing & Geometry | 22 | January 17, 2012 17:27 |
