Torque value obtained from ANYSYS Fluent is for wall or air around the wall |
December 27, 2020, 04:35 |
Jahaan
Rep Power: 6 |
Hi Everyone,
I have a small question. I have been doing a 2D simulation of flow over a rotating cylinder (Wall). i have used K-Omega solver with derived Y+ values and ran the simulation. I am confused from the derived torque value through Post processing window of Fluent "Reports → Forces → Moments → Select Wall → Print" . Please advice the derived torque value is of the air rotating over the cylinder OR it is only of Cylinder. Please share me a good reference to relate my scenario. Please see the attached images for quick references. thanks in advance Last edited by Jahaan; December 27, 2020 at 04:37. Reason: added new line |
December 28, 2020, 14:54 |
Rep Power: 27 |
Stupid question maybe, but aren't they the same?
December 31, 2020, 01:08 |
Jahaan
Rep Power: 6 |
Firstly thanks for your reply.
I am bit skeptical about it, if both are same then theoretically calculated torque values of rotating cylinder and the ANSYS torque values of rotating wall are different. Being a senior member of this page, It will be good if you can be helpful, instead of saying it a stupid question. I am just starting my self with CFD, trying to explore things out and reaching for help. I would be more happy if i get any help, where i would like to correct myself. Last edited by Jahaan; December 31, 2020 at 03:54. |
December 31, 2020, 19:42 |
Rep Power: 27 |
I didn't mean to say that your question is stupid, I meant that my question might be stupid.
2d flow over a cylinder, fluent, rotating body, torque |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 02:08 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
