Error: GENERAL CAR CDR - User-Defined-Material-Database |
December 21, 2020, 09:01 |
Eva Knahl
Rep Power: 5 |
I would like to create two fabrics using the User Defined Material Database in Fluent.
I am working with Ansys 2020 R1 or R2 (both in use - files do not mix). For this I used the following procedure: User defined Material database in FLUENT I created an empty Scheme file and edited it with Fluent. There I set constant values for the acentric factor and the kiritic point. For cp, density, thermal conductivity and viscosity I want piecwise polynomial (3 rank with 3 coefficients). I had also tried polyinomial with 7 coefficients.... I get the same error every time: Error: GENERAL-CAR-CDR: invalid argument [1]: improper list This error appears every time when starting the calculation and very often already when copying from the User-Defined-Material-Database. I have also tried the following way. user defined new material But for this I copied the materials from the Scheme file. This leads to the fact that the substances appear in the Fluent-Database, but this leads to the same error when I want to copy/create the substances. Is it possibly due to the piecewise polynomial assignment? Have I ignored a step or am I forgetting something in the schema file? (e_g fluid (chemical-formula . #f) (acentric-factor (constant . 0.09950000000000001)) (specific-heat (polynomial piecewise-polynomial (289.79 295. 2730669. -18393.334733 31.015439) (295. 300.5 612790.6021 -3997.16224 6.55105) (300.5 306. 246111.7724 -1552.2795 2.4756244)) (real-gas-law . #f) (constant . 0.09950000000000001)) (critical-pressure (constant . 4872200.) (polynomial piecewise-polynomial (289.79 295. 2730669. -18393.334733 31.015439) (295. 300.5 612790.6021 -3997.16224 6.55105) (300.5 306. 246111.7724 -1552.2795 2.4756244)) (real-gas-law . #f)) (critical-volume (constant . 0.00485) (polynomial piecewise-polynomial (289.79 295. 2730669. -18393.334733 31.015439) (295. 300.5 612790.6021 -3997.16224 6.55105) (300.5 306. 246111.7724 -1552.2795 2.4756244)) (real-gas-law . #f)) (critical-temperature (constant . 305.32) (polynomial piecewise-polynomial (289.79 295. 2730669. -18393.334733 31.015439) (295. 300.5 612790.6021 -3997.16224 6.55105) (300.5 306. 246111.7724 -1552.2795 2.4756244)) (real-gas-law . #f)) (density (polynomial piecewise-polynomial (289.79 295. 7070.2037820704 -46.398193926 0.07683156694) (295. 300.5 2992.4518829 -18.701474026 0.029801199) (300.5 306. 1766.722568 -10.5323227 0.01618981)) (constant . 305.32) (real-gas-law . #f)) (latent-heat) (molecular-weight (constant . 30.069) (polynomial piecewise-polynomial (289.79 295. 7070.2037820704 -46.398193926 0.07683156694) (295. 300.5 2992.4518829 -18.701474026 0.029801199) (300.5 306. 1766.722568 -10.5323227 0.01618981)) (real-gas-law . #f)) (reference-temperature (constant . 285.15) (polynomial piecewise-polynomial (289.79 295. 7070.2037820704 -46.398193926 0.07683156694) (295. 300.5 2992.4518829 -18.701474026 0.029801199) (300.5 306. 1766.722568 -10.5323227 0.01618981)) (real-gas-law . #f)) (speed-of-sound (constant . 230.13) (polynomial piecewise-polynomial (289.79 295. 0.00033736625857 -2.20486957e-06 3.722146e-09) (295. 300.5 0.0001359195 -8.365594405560001e-07 1.398601399e-09) (300.5 306. 7.03099060939e-05 -3.990819180817e-07 6.693306693000001e-10)) (polynomial piecewise-linear (0. . 0.) (0. . 0.)) (real-gas-law . #f)) (thermal-conductivity (constant . 0.02968) (polynomial piecewise-polynomial (289.79 295. 0.00033736625857 -2.20486957e-06 3.722146e-09) (295. 300.5 0.0001359195 -8.365594405560001e-07 1.398601399e-09) (300.5 306. 7.03099060939e-05 -3.990819180817e-07 6.693306693000001e-10)) (polynomial piecewise-linear (0. . 0.) (0. . 0.)) (real-gas-law . #f)) (viscosity (polynomial piecewise-polynomial (289.79 295. 0.00033736625857 -2.20486957e-06 3.722146e-09) (295. 300.5 0.0001359195 -8.365594405560001e-07 1.398601399e-09) (300.5 306. 7.03099060939e-05 -3.990819180817e-07 6.693306693000001e-10)) (polynomial piecewise-linear (0. . 0.) (0. . 0.)) (constant . 285.15) (real-gas-law . #f)) (therm-exp-coeff (constant . 0)) ) (e-liq fluid (chemical-formula . #f) (acentric-factor (constant . 0.09950000000000001)) (specific-heat (polynomial piecewise-polynomial (270. 276.5 86021.53558 -643.444643 1.24863) (276.5 283. 217730. -1594.08283 2.964011) (283. 289.79 980190.171973 -6962.76209 12.41463)) (constant . 0.09950000000000001)) (critical-pressure (constant . 4872200.) (polynomial piecewise-polynomial (270. 276.5 86021.53558 -643.444643 1.24863) (276.5 283. 217730. -1594.08283 2.964011) (283. 289.79 980190.171973 -6962.76209 12.41463))) (critical-volume (constant . 0.00485) (polynomial piecewise-polynomial (270. 276.5 86021.53558 -643.444643 1.24863) (276.5 283. 217730. -1594.08283 2.964011) (283. 289.79 980190.171973 -6962.76209 12.41463))) (critical-temperature (constant . 305.32) (polynomial piecewise-polynomial (270. 276.5 86021.53558 -643.444643 1.24863) (276.5 283. 217730. -1594.08283 2.964011) (283. 289.79 980190.171973 -6962.76209 12.41463))) (density) (molecular-weight (constant . 30.069) (polynomial piecewise-polynomial (270. 276.5 86021.53558 -643.444643 1.24863) (276.5 283. 217730. -1594.08283 2.964011) (283. 289.79 980190.171973 -6962.76209 12.41463))) (reference-temperature (constant . 285.15) (polynomial piecewise-polynomial (270. 276.5 86021.53558 -643.444643 1.24863) (276.5 283. 217730. -1594.08283 2.964011) (283. 289.79 980190.171973 -6962.76209 12.41463))) (speed-of-sound (polynomial piecewise-polynomial (270. 276.5 -2074.136 30.09596 -0.07409341) (276.5 283. -6478.40365 61.9003 -0.131511) (283. 289.79 -22555.67871 175.191406 -0.331094)) (constant . 285.15)) (thermal-conductivity (polynomial piecewise-polynomial (270. 283. 0.150099526 0.000441038 -2.379121e-06) (283. 289.79 -0.4129611463008 0.004445709185 -9.500693223e-06)) (constant . 285.15)) (viscosity (polynomial piecewise-polynomial (270. 276.5 0.00022985144066 -3.5231099e-07 -9.780219999999999e-10) (276.5 283. -4.04156395605193e-05 1.5997178571434e-06 -4.5027472527e-09) (283. 289.79 -0.00095385194 8.037289999999999e-06 -1.5845286e-08)) (constant . 285.15)) ) |
error general car cdr, scheme file, user defined material |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 06:37 |
User Defined Material Equation - Error message | .bastian | CFX | 4 | July 30, 2018 10:49 |
User defined time step - Possible to put variable time stepping in it? | maccheese | Fluent UDF and Scheme Programming | 19 | June 4, 2018 10:49 |
User defined memory value changing | minhoabc | FLUENT | 2 | June 22, 2017 07:28 |
How to use User defined database to add material | sangeeta | FLUENT | 1 | February 25, 2009 14:02 |
