finite volume method and finite difference method
Old   December 21, 2020, 06:46
Default finite volume method and finite difference method
Harishkumar
harishkamat100 is on a distinguished road
Hi
Can we compare the results obtained from the finite volume method (ANSYS fluent) and the finite difference method (MATLAB) for validation. Whether results obtained from both methods will be same?
harishkamat100 is offline   Reply With Quote
Old   December 21, 2020, 13:22
pakk will become famous soon enough
Of course you can compare them. Plot them both, and see if they agree, who is stopping you?
If you are solving the same physical problem, both with proper numerical settings, the results should be the same (within numerical accuracy). Otherwise one of the two methods would be conceptually wrong.
pakk is offline   Reply With Quote
Old   December 22, 2020, 00:25
Harishkumar
Thank you for the info.
Actually, the following literature mentioned that results won't be the same.
"CFD analysis of journal bearing hydrodynamic lubrication by Bingham lubricant"
Old   December 22, 2020, 00:52
That just means one of the two does not have proper numerical settings. If they did, they should both approximate reality, and therefore each other.
How to tell if they have proper numerical settings, that is a different, much more difficult story.
The fundamental difference between Finite Difference and Finite Volume Methods vikramaditya91 Main CFD Forum 3 January 14, 2016 05:13
Control volume based finite difference method? mukut.medhi Main CFD Forum 3 August 24, 2012 11:01
Control Volume , Finite Volume, Finite Control Volume, Finite Element Method technocrat.prakash Main CFD Forum 1 April 24, 2010 20:24
Comparison: Finite Volume Method vs. Analytic Method m-fry Main CFD Forum 1 April 20, 2010 15:40
Finite volume method vs finite difference method? superfool Main CFD Forum 4 October 21, 2006 15:37
