ANSYS Fluent analysis stops after some time.
Old   December 21, 2020, 05:59
Default ANSYS Fluent analysis stops after some time.
Kalpit Prajapati
KalpitPraj is on a distinguished road
I'm running a 2D analysis of a turbine using the 6 DOF method in ANSYS fluent with parallel processing. The total runtime is 40 seconds with 8000-time step where 1-time step is 0.005 seconds. The calculation runs for about 20 seconds and stops abruptly without any error prompt with simulation completed as a message in the dialog box. I've tried this on multiple ANSYS versions, 2016,2019,2019 R2 but the problem remains the same.
I'm running on a 6 core system with 12 processes on parallel processing. Can anyone point out whether it's a hardware issue or a software issue?
KalpitPraj is offline   Reply With Quote
Old   December 22, 2020, 02:29
duri
duri is on a distinguished road
It is difficult to understan what is happening from the given info, nevertheless try this. Is it converging to steady state after 20s? Try removing convergence stop criteria.
duri is offline   Reply With Quote
Old   December 23, 2020, 04:32
Kalpit Prajapati
Thanks for replying. I'm fairly new to using ANSYS fluent can you guide on how to remove convergence stop criteria. Also I ran the analysis again with much lower residuals magnitude to 1e-7 still the analysis some what stopped before 22.5 seconds at 4406 time step. Kindly look at the attached snips to get more clarity.
Old   December 24, 2020, 03:04
duri
It occurs after partition and not due to iteration. Try running in serial or less number of cores or try changing partition method. It could be a software issue.
ansys, ansys 2020, fluent, fluent - parallel
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 08:09
How to combine ANSYS Fluent and Structural analysis? diwakar ANSYS 2 June 18, 2015 13:07
Two way Fsi Problem- Non linear problem kmgraju CFX 4 April 28, 2015 12:15
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
