friction factor calculation in an air heater with jet impingement
Old   December 20, 2020, 14:19
Default friction factor calculation in an air heater with jet impingement
ali akbar salehi
ali akbar salehi is on a distinguished road
Hello. I want to calculate friction factor through air heater with a jet plate between bottom plate and absorber. What I calculated as pressure loss in test section is about 65 Pascals according to air as working fluid and Reynods number of 3500.I used f=deltap*D/2*ro*l*v2squared and I used RNG k-epsilon method. My problem is that I don't know what should I use as v and how to calculate deltap in test section(in simple air heater case I could validate my answers with assumption of velocity inlet as v and pressure loss between test section inlet and test section outlet).
Thanks in advance.
ali akbar salehi is offline   Reply With Quote
Old   December 21, 2020, 01:56
Default image
ali akbar salehi
And this is my geometry if it could help you besides average Nu no that I calculated is correct. I think I should use another way to calculate pressure loss or velocity in this geometry.
air heater, friction coefficient, jet impingement, perforated plate
Supersonic Jet Impingement over a flat plate Smaras FLUENT 3 June 7, 2013 04:55
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
Water Jet Impingement Ahmed Omar CFX 0 April 13, 2006 19:20
Help!!!problems in air jet into water bath kim FLUENT 4 June 9, 2003 08:04
JET IMPINGEMENT G.Balakrishnan FLUENT 1 December 9, 2000 13:17
