Patching a circular zone
Old   December 18, 2020, 07:33
Default Patching a circular zone
Koo Ian Keen
mitosis is on a distinguished road
Hi, i am a beginner to ansys fluent. I am doing a 2D simulation of methane air combustion in a square chamber (200mm X 200mm). The ignition point (a circle D=10mm) is at the centre of the square mesh. I want to patch the ignition point so that the initial temperature for the ignition point is very high. How do i make fluent to create a circular zone at the middle so that i can patch it?
mitosis is offline   Reply With Quote
Old   December 18, 2020, 07:58
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
fluent GUI -> adapt -> mark/adapt cells -> region adaptation -> select sphere and put parameters -> press MARK
initialize case, press PATCH, select temperature as variable -> select marked region in Registers to Patch window
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   December 18, 2020, 08:17
Koo Ian Keen
where is fluent GUI? I am using Ansys Fluent 2020R1 Revision: 20.1.0
Old   December 18, 2020, 09:13
Alexander
graphical interface
best regards
Old   December 18, 2020, 09:34
Koo Ian Keen
graphical interface
hi, which exact button should i click? Sorry, this is my first time learning CFD.
https://photos.app.goo.gl/fWCapUCvfwt6ztGf6
Old   December 18, 2020, 15:22
pakk will become famous soon enough
It just means that you use the menu.
pakk is offline   Reply With Quote
patch by zone
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
patch error OF v2.2.2 mac hewei OpenFOAM Installation 4 November 30, 2013 17:55
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 17:46
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
