Fluent *dat file wrote with only need variables |
December 18, 2020, 00:55 |
Konstantin
Rep Power: 11 |
Hello, bro!
Can anybody help me to find out how to write fluent *dat file with only variables that i need in my solver? For example, i solve the flow and in the future i need only velocity component, so... where i can indicate to write in *dat file only velocity without density, temperature and other variables? I need that because my *dat files is very big and i want to did it smaler. best regard for all. Last edited by DzhoniD; December 18, 2020 at 02:08. |
December 18, 2020, 06:07 |
Rep Power: 8 |
I suggest saving .cdat files instead of .dat if your concern is having a rich time-series for post-processing. The files are usually smaller for the few variables of interest.
Calculation activities (left-click twice, NOT on the arrow for the droplist) -> automatic export -> create -> solution data export. In "file type" make sure you choose "CFD-Post compatible" (for .cdat) if you are indeed post-processing with CFD-Post. Below you can choose the saving frequency (in respect to the time-steps or flow-time). To the right, in "quantities" choose all your variables of interest for exporting. As .cdat file are not compatible with Fluent's interface, make sure you save some .dat files in a while, in case you want to restart your processing from a previous solution or something goes wrong. |
December 22, 2020, 03:42 |
Konstantin
Rep Power: 11 |
fluent, write data, write to file |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 36 | July 16, 2024 03:52 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
