Problem in UDF for dynamic mesh
Old   December 16, 2020, 06:58
Default Problem in UDF for dynamic mesh
Dnyanesh Mirikar
DnyanMiri is on a distinguished road
Hello everyone,
I'm trying to simulate synthetic jet, where bottom wall oscillates according to the displacement equation.
X=a*s*sin(2*pi*f*t)
I have created an UDF, which gets compiled but when I start solution it shows error before first iteration. (screenshot is attached below).
UDF I have created is as following
#include "udf.h"
DEFINE_GRID_MOTION(diaphragm, domain, dt, time, dtime)
int n;
Node *node;
face_t f;
real a, rad, r, rc, s, p, freq, A;
real xc[ND_ND];
a = 0.0002;
rad = xc[0];
if (rad<0)
rad *= -1;
r = rad;
rc = 0.0225;
s = (1-(r/rc));
p = 3.1425;
freq = 150;
Thread *t = DT_THREAD(dt);
SET_DEFORMING_THREAD_FLAG (THREAD_T0 (t));
begin_f_loop (f, t)
f_node_loop (f, t, n);
node = F_NODE (f, t, n);
A = a*s*sin(2*p*freq*time);
NODE_Y (node) = A;
end_f_loop (f, t)
Please guide me what I'm doing wrong. I'm new to dynamic mesh settings. Thank you for your help.
DnyanMiri is offline   Reply With Quote
Old   December 18, 2020, 00:32
Default Parallelization of UDF
Dnyanesh Mirikar
I was able set UDF for my dynamic mesh Here is the UDF.
Now problem is that I want to speed up my solution, so parallelization is needed. I have gone through the user manual but I was not able to grasp fully what need to be done. If you help point out whats need to be change to convert this for parallel use, I would be grateful. Thank you!
#include "udf.h"
DEFINE_GRID_MOTION(diaphragm,domain,dt,time,dtime)
real amp,dy0,omega;
amp=0.0005; /*amplitude of the oscillatory motion 5mm*/
omega=942; /*oscillations frequency*/
#if !RP_HOST
int n;
Thread *tf = DT_THREAD(dt);
face_t f;
Node *v;
SET_DEFORMING_THREAD_FLAG(THREAD_T0(tf));
begin_f_loop(f,tf)
f_node_loop(f,tf,n)
v=F_NODE(f,tf,n);
if (NODE_POS_NEED_UPDATE (v))
NODE_POS_UPDATED(v);
dy0=amp*sin(omega*time); /*the displacement of the bottom wall in the Y direction*/
NODE_Y(v)=NODE_Y(v)+dy0;
end_f_loop(f,tf);
#endif
dynamic mesh, grid motion, oscillation, synthetic jet, udf
udf for valve closing a pipe using dynamic mesh chem engineer Fluent UDF and Scheme Programming 2 May 13, 2017 10:39
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Need HELP in writing UDF for a dynamic mesh problem farrux Fluent UDF and Scheme Programming 0 July 3, 2015 03:53
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
