When I wrote the dat file, the following error occurred: |
December 8, 2020, 09:54 |
#1 | ||
Rep Power: 7 |
December 8, 2020, 14:30 |
Rep Power: 26 |
Is your model by any chance very large? Hundreds of millions of cells, or more?
December 8, 2020, 20:16 |
Rep Power: 7 |
December 8, 2020, 20:32 |
Rep Power: 26 |
Then you just should consider it bad luck, exit Fluent, start from your last saved files that worked, and do the work again.
If the problem repeats, contact Ansys and tell them exactly what you do to get this problem. |
December 9, 2020, 02:13 |
Rep Power: 7 |
My cell count is less than 100,000, and restarting the computer is useless, the computer I am using has 64GB of RAM. I have used other versions of Fluent and this problem still occurs. I used workbench to read this case/dat, and it prompted me that the mesh and data did not match. I don’t understand that the case/dat saved together will have a mismatch problem, and it can still be calculated well (the calculation process is okay, and the calculation results look reasonable), which is really incredible, and finally I regenerate the data through the interpolation function. In the subsequent calculations, the error of not being able to save dat has appeared.
December 17, 2020, 02:38 |
fluent data problem
vijayakumar d
unfortunately i changed the data file into notepad format, now i cannot access the data file. please kindly somebody help me
December 17, 2020, 08:30 |
Rep Power: 26 |
What does it mean, "changed the data file into notepad format"?
error, fluent, write dat |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
