Calculated torque value not matching with fluent value |
December 6, 2020, 08:53 |
Jahaan
Rep Power: 6 |
Hi everyone
I am a student, recently gained intrest in CFD and started working on small cases to learn and understand tool and physics. I have been working on a simple case of "transient simulation, Flow over a rotating circle -2D". I am using pressure inlet and outlet as boundry conditions, with constant RPM. My challenge is i am not able to match calculated torque value and fluent torque value. Also I have observed that torque value is changing with time even tough with constant RPM Need help to figure out my case. Thanks in advance |
December 6, 2020, 20:42 |
Rep Power: 27 |
If you want help, you have to share some more details.
At minimum: -which pressures and flow rate did you use? -what is the torque value calculated by you? -how did you calculate that? -what is the torque value calculated by fluent? |
December 10, 2020, 12:03 |
Jahaan
Rep Power: 6 |
Hi Pakk,
Thanks for your reply, my apologies for not giving complete information. I have used simple model of (R)0.07m circle in a rectangular domain, Circle rotating with 1780.23 rad/sec. I have used KOmega solver with boundry condition (Pressure inlet and pressure outlet) in transient case and ran for 4 sec, ANSYS torque value is 19Nm. I have theoretically calculated torque value by (Moment of inertia of circle (I) X Angular acceleration (Alpha)) and the derived value is 0.008Nm. I am not able to understand where i am going wrong. Thanks for asking me :-) |
flow over a cylinder, fluent, torque, transient |
Torque calculation with fluent | s wang | FLUENT | 11 | February 9, 2017 10:45 |
Pressure calculated by Fluent | souria | FLUENT | 4 | November 10, 2015 04:30 |
Torque in Fluent | visitor | FLUENT | 0 | November 7, 2015 04:44 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 10:28 |
